SCADE Replaces Values with Null in Textual Expressions Causing Check Failure
December 4, 2024 at 6:50 am
spiritual122899
Bbp_participantHi Ansys Community,
I am a Test Engineer from mainland China, and I have encountered an issue with SCADE Suite during my testing process. Specifically, this issue occurs when opening a textual expression written in a certain way, which causes some values in the model to be replaced by
null, resulting in a check failure.Steps to Reproduce the Issue:
- Create
Operator1(Input1: bool; Input2: bool)which returns(Output1: bool)and implements the functionalityOutput1 = Input1 or Input2. - Create
Operator2()which returns(Output1: bool). InsideOperator2, use a textual expression to callOperator1(true, false)and directly connect it toOutput1. - Perform a check on
Operator2—it passes successfully, then save and close the SCADE project. - Reopen the project in SCADE. During the opening process, SCADE will display the message:
  "Expression calls fixed in project: Operator2.xscade (1)" - When performing the check again on
Operator2, an error is displayed:
  "Illegal Empty Parameter at _L1 = Operator1(_null, _null)"
This issue is only observed when usingvaluedirectly as an input to the callee in the expression.
Expected Behavior:
Since I have made no modifications to the model, I expect that simply performing a check on
Operator2should not trigger any errors, and the check should pass successfully without any issues.Actual Behavior:
After reopening the model, checking
Operator2results in the error "Illegal Empty Parameter at _L1 = Operator1(_null, _null)". The values passed intoOperator1should not benullunder normal circumstances.Environment:
- SCADE Suite Version: 2023R1
- Operating System: Windows 10 Enterprise 22H2
Background:
This issue was discovered while using SCADE Suite in a minimal example that I created to reproduce the problem. The issue occurs under very basic conditions, meaning that it can be triggered by a very simple test project, as described above. I am happy to provide the
.etpand.xscadefiles for further investigation.I would appreciate any help or information regarding whether this issue is already known and if there is any existing workaround or fix available.
Thank you for your time and support!
- Create
December 4, 2024 at 12:43 pm
Benjamin Descorps
