March 28, 2025 at 5:22 pm
mihnea.apostolescu
SubscriberHello!
I encountered two issues while I was trying to convert a .keras convolutional neural networked trained and saved using tensorflow 2.16.1. I encountered the error below when I called the method : keras_importer.importer.model_import(loaded_model, "scade_model_path"), where loaded_model was my .keras CNN loaded using the tensorflow method keras_CNN_model = tf.keras.models.load_model(keras_CNN_path, compile=False)
"ANSYS(R) SCADE(R) - Keras Importer - Version 20220216.16 (C) 2022 ANSYS, Inc. Unauthorized use, distribution, or duplication is prohibited. Importing keras model to scade ... Translation of Conv2D layer: conv2d (id: 2320059174448) 'Conv2D' object has no attribute 'input_shape' Error: Keras Importer execution failurec:\Users\\AppData\Local\Programs\Python\Python312\Lib\site-packages\keras\src\layers\core\input_layer.py:25 : UserWarning: Argumentinput_shape
is deprecated. Useshape
instead. warnings.warn(1
That "1" is printed due to the return in the model_import method of the keras importer, which is part of the SCADE NN Package.
I tried converting a Keras model trained and saved using tensorflow 2.16.1 because of the compatibilities that the Nerual Networks Package described in its documentation :
However, I tried installing older versions of tensorflow (mostly 2.6.0) on a virtual environment which used python 3.9.4. Tensorflow 2.6.0 was not compatible with Python 3.12 which I used in the begining.
However, even if I tried installing the 2.6.0 versions of tensorflow and its tensorboard and tensorflow-estimator dependencies, I haven't succeeded in importing the keras importer of the SCADE NN Package afterwards. This is the error I encountered :
---------------------------------------------------------------------------ImportError Traceback (most recent call last)Cell In[1], line 53 SCADE_keras_importer_path = os.path.join(os.getcwd(), 'ACT_Neural_Networks_Package_v1', 'src')4 sys.path.append(SCADE_keras_importer_path)----> 5 import keras_importer.importer as ki6 import tensorflow as tfFile c:\\SCADE implementation\ACT_Neural_Networks_Package_v1\src\keras_importer\importer.py:101 96 return opts98 ###########################################################################99 # Model translation--> 101 def import_model(model:tf.keras.Model) -> scade.Model:102 # initialize project from template103 dir = module.opts['target_dir']104 res_dir = pathlib.Path(script_dir) / ".." / ".." / "resources" / "keras_importer"File c:\\scade_environment\lib\site-packages\tensorflow\python\util\lazy_loader.py:62, in LazyLoader.__getattr__(self, item) 61 def __getattr__(self, item):---> 62 module = self._load()63 return getattr(module, item)File c:\\scade_environment\lib\site-packages\tensorflow\python\util\lazy_loader.py:45, in LazyLoader._load(self) 43 """Load the module and insert it into the parent's globals."""44 # Import the target module and insert it into the parent's namespace---> 45 module = importlib.import_module(self.__name__)46 self._parent_module_globals[self._local_name] = module48 # Emit a warning if one was specifiedFile C:\Python39\lib\importlib\__init__.py:127, in import_module(name, package)125 break126 level += 1--> 127 return _bootstrap._gcd_import(name[level:], package, level)File c:\\scade_environment\lib\site-packages\keras\__init__.py:3 1 """AUTOGENERATED. DO NOT EDIT."""----> 3 from keras import __internal__4 from keras import activations5 from keras import applicationsFile c:\\scade_environment\lib\site-packages\keras\__internal__\__init__.py:3 1 """AUTOGENERATED. DO NOT EDIT."""----> 3 from keras.__internal__ import backend4 from keras.__internal__ import layers5 from keras.__internal__ import lossesFile c:\\scade_environment\lib\site-packages\keras\__internal__\backend\__init__.py:3 1 """AUTOGENERATED. DO NOT EDIT."""----> 3 from keras.src.backend import _initialize_variables as initialize_variables4 from keras.src.backend import track_variableFile c:\\scade_environment\lib\site-packages\keras\src\__init__.py:21 1 # Copyright 2015 The TensorFlow Authors. All Rights Reserved.2 #3 # Licensed under the Apache License, Version 2.0 (the "License");(...)13 # limitations under the License.14 # ==============================================================================15 """Implementation of the Keras API, the high-level API of TensorFlow.1617 Detailed documentation and user guides are available at18 [keras.io](https://keras.io).19 """---> 21 from keras.src import applications22 from keras.src import distribute23 from keras.src import modelsFile c:\\scade_environment\lib\site-packages\keras\src\applications\__init__.py:18 1 # Copyright 2016 The TensorFlow Authors. All Rights Reserved.2 #3 # Licensed under the Apache License, Version 2.0 (the "License");(...)13 # limitations under the License.14 # ==============================================================================15 """Keras Applications are premade architectures with pre-trained weights."""---> 18 from keras.src.applications.convnext import ConvNeXtBase19 from keras.src.applications.convnext import ConvNeXtLarge20 from keras.src.applications.convnext import ConvNeXtSmallFile c:\\scade_environment\lib\site-packages\keras\src\applications\convnext.py:28 25 import numpy as np26 import tensorflow.compat.v2 as tf---> 28 from keras.src import backend29 from keras.src import initializers30 from keras.src import layersFile c:\\scade_environment\lib\site-packages\keras\src\backend.py:34 32 from keras.src import backend_config33 from keras.src.distribute import distribute_coordinator_utils as dc---> 34 from keras.src.dtensor import dtensor_api as dtensor35 from keras.src.engine import keras_tensor36 from keras.src.utils import control_flow_utilFile c:\\scade_environment\lib\site-packages\keras\src\dtensor\__init__.py:18 1 # Copyright 2022 The TensorFlow Authors. All Rights Reserved.2 #3 # Licensed under the Apache License, Version 2.0 (the "License");(...)13 # limitations under the License.14 # ==============================================================================15 """Keras' DTensor library."""---> 18 from tensorflow.compat.v2.experimental import dtensor as dtensor_apiImportError: cannot import name 'dtensor' from 'tensorflow.compat.v2.experimental' (c:\\scade_environment\lib\site-packages\tensorflow\_api\v2\compat\v2\experimental\__init__.py) Could you please help me solve these issues and find a solution for using the keras importer and the python wrapper included in the SCADE NN Package?
Thank you in advance! -
April 2, 2025 at 9:31 am
Romain Andrieux
Ansys EmployeeHello,
Indeed the SCADE Neural Network Package is not updated to work with the latest verion of Keras & Tensorflow.
I could make it work with the following environment:
- Python 3.11
- Keras 2.12.0
- Tensorflow 2.12.0
Try to run the exemple lenet.py to see if your environment is correct.
Note: to make the exemple lenet.py work, you'll need to download all the training data from:
https://github.com/golbin/TensorFlow-MNIST/tree/master/mnist/data
into examples/lenet/data folder, and comment out lines 134 & 135.
Let me know if that solves your issue.
Regards
Romain
April 2, 2025 at 8:14 pm
mihnea.apostolescu
SubscriberHello Romain,
Thank you for your answer. Unfortunately, the LeNet example didn't work with none of 2.16.1, 2.12.0 or 2.6.0 tensorflow versions.
This is the output I received in the environment I installed tensorflow 2.16.1 on :
WARNING:absl:You are saving your model as an HDF5 file via
model.save()
orkeras.saving.save_model(model)
. This file format is considered legacy. We recommend using instead the native Keras format, e.g.model.save('my_model.keras')
orkeras.saving.save_model(model, 'my_model.keras')
Downloading data from https://storage.googleapis.com/tensorflow/tf-keras-datasets/mnist.npz
11490434/11490434 ━━━━━━━━━━━━━━━━━━━━ 1s 0us/step
channels_last
x_train shape: (60000, 28, 28, 1)
60000 train samples
10000 test samples
Traceback (most recent call last):
File "\SCADE implementation\ACT_Neural_Networks_Package_v1\examples\lenet\lenet.py", line 147, in
lenet.step2_train()
File "\SCADE implementation\ACT_Neural_Networks_Package_v1\examples\lenet\lenet.py", line 89, in step2_train
y_train = keras.utils.np_utils.to_categorical(y_train, self.num_classes)
AttributeError: module 'keras.utils' has no attribute 'np_utils'This is the output I received in the environment I installed tensorflow 2.12.0 on :
(The command I used to install it in order to satisfy all the necessary dependencies is this : pip install "tensorflow==2.12.0" "tensorboard==2.12.0" "tensorflow-estimator==2.12.0" "protobuf==4.0.0rc2" "numpy==1.22.4")
PS
\SCADE implementation\ACT_Neural_Networks_Package_v1\examples\lenet> python .\lenet.py
File "\SCADE implementation\ACT_Neural_Networks_Package_v1\examples\lenet\lenet.py", line 10, in
import keras
File "\scade_environment\lib\site-packages\keras\__init__.py", line 21, in
from keras import models
File "\scade_environment\lib\site-packages\keras\models\__init__.py", line 18, in
from keras.engine.functional import Functional
File "\scade_environment\lib\site-packages\keras\engine\functional.py", line 24, in
File "\scade_environment\lib\site-packages\tensorflow\__init__.py", line 37, in
from tensorflow.python.tools import module_util as _module_util
File "\scade_environment\lib\site-packages\tensorflow\python\__init__.py", line 37, in
from tensorflow.python.eager import context
File "\scade_environment\lib\site-packages\tensorflow\python\eager\context.py", line 28, in
from tensorflow.core.framework import function_pb2
File "\scade_environment\lib\site-packages\tensorflow\core\framework\function_pb2.py", line 5, in
from google.protobuf.internal import builder as _builder
ImportError: cannot import name 'builder' from 'google.protobuf.internal' (\scade_environment\lib\site-packages\google\protobuf\internal\__init__.py) This is the output I received in the environment I installed tensorflow 2.6.0 on :
(scade_environment) PS
2025-04-02 22:35:49.653427: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library 'cudart64_110.dll'; dlerror: cudart64_110.dll not found
2025-04-02 22:35:49.654636: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
import keras
File "\scade_environment\lib\site-packages\keras\__init__.py", line 3, in
File "\scade_environment\lib\site-packages\keras\__internal__\__init__.py", line 3, in
File "\scade_environment\lib\site-packages\keras\__internal__\backend\__init__.py", line 3, in
File "\scade_environment\lib\site-packages\keras\src\__init__.py", line 21, in
File "\scade_environment\lib\site-packages\keras\src\applications\__init__.py", line 18, in
File "\scade_environment\lib\site-packages\keras\src\applications\convnext.py", line 28, in
File "\scade_environment\lib\site-packages\keras\src\backend.py", line 34, in
File "\scade_environment\lib\site-packages\keras\src\dtensor\__init__.py", line 18, in
ImportError: cannot import name 'dtensor' from 'tensorflow.compat.v2.experimental' (\scade_environment\lib\site-packages\tensorflow\_api\v2\compat\v2\experimental\__init__.py) Could you help me with this? Thank you!
3150
1013
946
858
797
