January 19, 2024 at 12:22 pm
Łukasz Karmelita
SubscriberI have project in architect but i don't know how to connect scade suite to it. I wannt to have one project but with architect and suite in one place like in examples but cann't find option for it.
January 25, 2024 at 3:32 pm
Benjamin Descorps
Ansys Employee -
January 25, 2024 at 3:51 pm
Benjamin Descorps
Ansys EmployeeHello, You have to use the Synchronization module to synchronize your Architect project with a Suite project. To do this, you can go to the menu Project>Synchronization (or by using the Synchronization toolbar). You have first to edit the settings (Manage Synchronization) to set all the options (Architect object to synchronized, target Suite project, etc). Once this is done you could use the Push and Pull buttons to export/import data from both directions. I recommend you to have a look to the "Getting Started with SCADE Architect" document, section 6 / Managing Architect Models in Interdisciplinary Projects > Synchronizing Sub-System Components. It will guide you step by step to set-up your first synchronization. Benjamin
- The topic ‘Scade architect – connecting architect projec to scade suit’ is closed to new replies.
1333
1152
