August 7, 2021 at 3:46 am
mg
SubscriberAfter saving a model file, then clicking on File | Close, SC stopped responding. 2nd time this happened since new installation, on different project models. Request any info to help resolve this. Win error report enclosed. Thank you.
August 9, 2021 at 5:57 am
subashni.satish
Forum ModeratorHello maike
Can you also, please confirm if you have updated your graphics drivers to the latest version from the Graphics company website? Also, have you installed SpaceClaim with Administrator rights?
Does this issue happen for all files or any one particular file? If for one file, then can you please share the file with us, so that I can try to recreate the issue and check with the development team as required?If the issue persists after implementing the above suggestions, can you also share the log files?
The SpaceClaim log files can be found in C:Users
AppDataRoamingSpaceClaimLog Files.
You can the log files associated with the issue based on date, time.
Â-
August 9, 2021 at 8:42 am
mg
SubscriberSubashniÂ
Thanks, will report on your questions. Have worked with multiple scdoc files with no problem since that crash, which indicates some local issue or situation.
- The topic ‘SC2021R1 Not Responding’ is closed to new replies.
5899
1306
