March 22, 2023 at 5:42 am
design
SubscriberRecently updated to Spaceclaim 2023 R1.
When using ‘Pull’ or ‘Move’ the ‘Measure’ option does not work when selected from the mini-toolbar. The option appears but does not function.
It does work when selected from the main options panel.
Is this some kind of configuration issue, or a bug?
March 23, 2023 at 3:08 am
Atharv Joshi
Forum ModeratorHi SAC ,
Can you please share a short video on the problem you are facing?
Thanks and Regards
March 23, 2023 at 6:17 am
design
SubscriberSorry, I do not have video capability.
However I got the terminology wrong on my original post. The issue is the 'Ruler' option, not 'Measure'.
With the 'Pull' or 'Move' tool active, pick a surface. The mini toolbar pops up; pick the 'Ruler' option. No ruler appears. Pick 'Ruler' option from the main option panel and it works normally.
Sorry for the confusion and thanks for the response.
March 23, 2023 at 9:36 am
Atharv Joshi
I am unable to reproduce the problem. Ruler should appear after you move the cursor to fix the other end of the ruler. Please see the attached video.Â
Thanks and Regards
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​​
- The topic ‘SC 2023 R1’ is closed to new replies.
6179
