TAGGED: #fluent-#ansys, #fluent-#cfd-#ansys, command, command-line, fluent, text-commands
August 11, 2024 at 3:44 am
blanca.cerda
SubscriberHello,Â
I am trying to run fluent by commands.Â
Using the interactive window is something like:srun fluent -r23.2.0 2ddp -g -t20 -case/solve/dual-time-iterate/file/write-case-data/exit/close-fluentÂThis works really good, then i can read the results and everything works well.But trying the same commands through an sbatch file shows me the error after running the case and the data, considering the commands like a directory.Â
The sbatch looks something like this because is how the cluster works.Â#!/bin/bash#---------------Script SBATCH ----------------#SBATCH -J Simulacion#SBATCH -p general#SBATCH -n 1#SBATCH -c 20#SBATCH --mem-per-cpu=1000#SBATCH --mail-user=mail@mail.com#SBATCH --mail-type=ALL#SBATCH -o Simulacion152040_%j.err.out#SBATCH -e Simulacion152040_%j.err.out#-----------------Toolchain---------------------------ml purgeml intel/2022.00# ----------------Modulos----------------------------ml  ANSYS/2023R2 Â# ----------------Comando--------------------------export OMP_PLACES=coresÂsrun fluent -r23.2.0 2ddp -g -t20 -case/solve/dual-time-iterate/file/write-case-data/exit/close-fluentÂRunning this, i got:Â
ÂIs there a way from fluent to do all this properly?ÂThanks in advanceAugust 12, 2024 at 10:51 amRob
Forum ModeratorLooks like the Slurm script is trying to action the Fluent commands rather than them being used in Fluent. I'd favour launching Fluent with a journal, so the command launches Fluent with a journal which contains the read case & data, run, write case & data, exit. The Fluent part is covered in the User's Guide,  https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v242/en/flu_ug/flu_gs_starting.html  The Slurm part is likely something your IT people control.Â
August 12, 2024 at 7:30 pmblanca.cerda
SubscriberÂ
Hello dear,Â
I tried using a journal file, that i created as a text file, Thanks for the advice.
It worksÂ
Viewing 2 reply threads- You must be logged in to reply to this topic.
