August 28, 2023 at 4:34 am
Emirhan
SubscriberHello,
I'm trying to conduct a Transient Structural analysis using Workbench. I started to run the analysis without saving the Workbench. The solver is proceeding, however, it is not writing any data to any of the disks on the computer. It's been almost 12 hours since I started the analysis and it seems like the solution is converging at all time steps on solution information but I'm afraid that I'm going to lose all the solution at the end of the analysis (happened before to me in similar situations).
What would you recommend in my case to save the solution without a problem?
Thank you in advance.
August 28, 2023 at 10:23 am
Aniket Chavan
Forum Moderatorare you able to interrupt the solution process using interrupt button on the status window?
-Aniket
August 28, 2023 at 12:30 pm
Emirhan
SubscriberYes. My problem was that I couldn't find the location which it was writing the solution data since I have several disks. However, I found out that it was writing the solution data to the main disk of the computer so that I was able to save it. Thank you for your help reply.Â
- The topic ‘Transient Structural – Saving the Solution Data’ is closed to new replies.
6790
1332
1152
