December 6, 2022 at 10:08 am
ajones
Subscriber -
December 7, 2022 at 12:54 am
Subashni Ravichandran
Forum ModeratorHello Alex
Results of Explore mode cannot be saved. You will need to resolve it each time the file is launched.Â
Are you seeing an issue with results display when the file is relaunched and solved again?
December 7, 2022 at 6:06 am
ajones
SubscriberHi SubashniÂ
No problem solving again after re-launching. Just thought the results might be saved as there is an option to save without results. But sounds like this is only for the Refine studies.Â
Thank you for your quick answer to this oneÂ
AlexÂ
- The topic ‘Saving Results’ is closed to new replies.
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- Spaceclaim 2024 error FNE activation failed
- Ansys Discovery Crashing vGPU (Reproducible)
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
965
841
599
591
