December 6, 2021 at 4:39 pm
Syed Saif Ali
SubscriberHi,
Can you please help me with saving the optimized faceted optimized model only?
Thanks in advance!
Ali
December 6, 2021 at 4:47 pm
Charudatta Bandgar
SubscriberHello Syed Saif Ali
Let me get back to you.
Regards.
December 6, 2021 at 5:02 pm
Charudatta Bandgar
SubscriberHello Syed Saif Ali You can use this option to get the Optimized model.
Save this as .scdoc etc. What issue are you facing exactly? Do you want tos save just the optimized shape without the original geometry?
There isn't an option to export a single geometry right now, this feature is to be added in subsequent release, for now the workaround would be to import all the components and removing the ones that are not needed.
Regards.
December 6, 2021 at 5:11 pm
Syed Saif Ali
SubscriberI don't think we can directly import to .scdoc, there isn't a option.
Sometime it doesn't save the faceted body, is there a bug in Discovery?Â
December 7, 2021 at 4:30 am
Charudatta Bandgar
You are right, scdoc can not be exported, and when you export to step etc, the faceted geometry does not get exported sometimes. Sorry for the confusion. You can import the dsco file directly into SpaceClaim, it loses the simulation data, so make sure to make a duplicate and then open that dsco file into SpaceClaim. Although even with this, the original geometry will be present, which you might have to delete, if you need just the faceted body.Â
 We do see that sometimes non native formats do lose facet data, I have filed a bug ticket (560332) for it.
Regards.
December 7, 2021 at 10:15 am
Syed Saif Ali
SubscriberGreat, Thank you very much for your time.
Have a great day!
Ali
- The topic ‘Saving Faceted Optimization Model’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
4167
1487
1338
1171
