Save simulation results (report files) in Excel format: how to keep 1 file
    • Will3
      Hello Forum,
      I am performing a transient simulation and I export the results to a .csv (Excel) file. However, I have to run multiple simulations behind each other (resuming via interpolation files), so it belongs to one casus.
      I use:
      /solve/report-files/add/
      Currently, I loop this simulation 1000 times, but now also 1000 Excel-files are created. Since they are each others follow-up in time, I would like ANSYS to output all the results in 1 single .csv file. Any thoughts on how I could establish this?
      Best regards,
      Will
    • Will3
      An addition: another workaround would by to manually set the time step to a previous flowtime. Can this be done? If so, how: via the Text User Interface (TUI) code in the journal, or via another method?
      Thank you in adv
    • ai0013
      To obtain actual flowtime
      (rpgetvar 'flow-time)
      To set it to other time
      (rpsetvar 'flow-time ###)
    • Will3
    • Will3
      Why do you need the interpolation files to resume the run?
    • Will3
      Dear
      I am running 2 different simulations that cannot be combined (one using radiation, the other porous media). Thus I interpolate the transient radiation data (of the solar load model) into the second simulation including the porous media.
      Is it because of the interplation step that the report-file creates multiple .csv files instead of one?
      OK. If the solver thinks it's a new case the append data option for monitors may not work well.
Viewing 7 reply threads
  • The topic ‘Save simulation results (report files) in Excel format: how to keep 1 file’ is closed to new replies.
