TAGGED: #Modal_Analysis, apdl, mechanical, transient-structural
March 26, 2026 at 6:50 pm
gabriel.lucas
SubscriberHello,
I have a working APDL macro that runs a transient simulation to obtain the equilibrium position of a steel catenary riser (SCR), I can provide this macro if needed. A transient analysis is done to obtain the equilibrium position due to the way the geometry is initialized. Three load steps are used to obtain the equilibrium configuration.
I would like to save the deformed geometry yielded from the last time step and use it into a modal analysis to obtain the natural frequencies as well as the mode shapes for the structure.
I have been trying some things but nothing worked out as expected until now.Â
Does anyone have an idea on how I can do this?
Best regards,
Gabriel -
March 26, 2026 at 10:39 pm
peteroznewman
SubscriberIn APDL, the commands UPCOORD or UPGEOM are used to move node locations to their deformed position.
March 27, 2026 at 11:27 am
gabriel.lucas
SubscriberHello,Â
Thank you for your response!
These were two commands I tried using but could not get them to work.
March 27, 2026 at 6:39 am
ErKo
Ansys EmployeeÂ
Hello
See perhaps , how to run a linear perturbation analysis (modal). This will account for stress-stiffening/softening effects on the modes and use the deformed geom. from transient run (if nlgeom,on is used in the transient analysis).
See help for details and examples.
https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v261/en/ans_str/strlinpertproc.html
https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v261/en/ans_str/strlinpertinputs.html%23strlpexsimpmod
All the best
ErkoÂ
March 27, 2026 at 11:28 am
gabriel.lucas
SubscriberHello,
I will try this suggestion! -
March 30, 2026 at 1:17 pm
gabriel.lucas
SubscriberHello, Erko
Just to let you know, I was able to perform the modal analysis I wanted to thanks to your help!
However, there is one thing I am still skeptical about, I am not sure the stress effects are being considered, because when i try to plot the stress contour, the model gets coloured by a single color. Maybe the stresses are not being saved in the results file and that is why I cannot plot them?
5824
