3D Design
3D Design
Save error
    • Roberto
      Hello Sometimes SpaceClaim does not save by dropping the following error in the log file To save I have to close and reopen the software Regards
    • Charudatta Bandgar
       Hello Roberto
      Let me see what could the issue be. I will get back to you.
      Regards.
    • Roberto
      Hello Charudatta Bandgar I don't understand why it doesn't create a crease between these two sheets Regards
      ? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello Roberto
      Can you please send the files, and the complete log files of the save error you are getting? I would like to try it on my end and see if we can find anything. (If you want I can send the secure transfer link).
      Also is the the other query you asked here, with regards to the crease not getting created related to the file w which we are getting the crease error, if not would you mind if we do that in separate query discussion so that it will be easier to keep track?
      Regards.
    • Roberto
      Hello Charudatta Bandgar I am attaching the log file here, for the sheet metal problem I am opening a new ticket. I am sending the file to you by secure link Regards
Viewing 4 reply threads
  • The topic ‘Save error’ is closed to new replies.
