July 7, 2019 at 8:12 am
prashant
SubscriberHow to plot sauter mean diameter with respect to distance -
July 8, 2019 at 8:42 am
Amine Ben Hadj Ali
Ansys EmployeeWhich software you are using? Which distance? Can you add more details so that we are able to reply.
July 9, 2019 at 3:19 am
prashant
SubscriberI am using fluent, I have made a cylindrical geometry with pressure swirl injection in the axial direction at the top surface. so I want to calculate SMD at different locations of the domain.
July 9, 2019 at 10:15 am
Forum ModeratorIs it a steady or transient DPM calculation?
July 9, 2019 at 2:34 pm
prashant
SubscriberIt is a transient simulation,although i want to lean for cases -
July 10, 2019 at 10:49 am
Forum ModeratorThe particle size can be plotted on the DPM tracks. If you create a surface you can also run a DPM Summary: I think you can calculate the Sauter mean diameter from that output file.Â
July 11, 2019 at 11:12 am
Amine Ben Hadj Ali
Ansys Employeecheck Summary Reporting of Current Particles in the User's Guide for definitions!
July 11, 2019 at 4:02 pm
prashant
SubscriberActually I have made a cylindrical geometry I want to create surface of specified dimensions, but I am unable to make it. Next I want to extract particle summary in that particular domain.
I have already extracted Particle summary through console window but it is providing data for whole domain.
So overall I need value of SMD particular domain.
Your response is solicited. Thanks for helping me. -
July 11, 2019 at 4:16 pm
Forum ModeratorThen you need to create planes or fluid regions to report on. Have a look at surface creation and see if that does what you need.Â
- The topic ‘Sauter mean diameter’ is closed to new replies.
- affinity not set
4167
1487
1363
1194
