TAGGED: cfd, evaporation-condensation, fluent, udf-fluent
July 20, 2021 at 3:37 pm
TryingMyBest1232
SubscriberHello all,
I have been trying to model evaporation at temperatures far well below 100C. This is primarily driven by the vapor content of air at the water-air interface.
I found this discussion on the problem where a user had developed a UDF to solve this problem (see a version with a few adjustments below) : /forum/discussion/26620/saturation-temperature-udf-for-evaporation-condensation
The setup this is used with has 2 phases, one a mixture of air and water vapor and the other is water.
The results of using the UDF seem wrong intuitively. On a test where I ran warm air over a pool of water, the drier air had a higher saturation temperature and the lower air had a lower saturation temperature. Additionally, the fluctuation of saturation pressures across the domain is of the order 1e-1 which is much too low.
I think the calculation of partial pressure on line 75 is wrong:
(C_P(c, t)+ p_op)* (N_wv / N_total)
I'm not sure if it should be this, or:
(C_P(c, t))* (N_wv / N_total) + p_op
or:
or something else entirely. To me the final option makes sense, but this could lead to an error as there would be log_10(0) on line 81.
Any advice would be appreciated.
Cheers
#include "udf.h"
#define MOLAR_MASS_WATER 18.01534 //g/mol
#define MOLAR_MASS_AIR 28.97 // g/mol
#define RHO_WV 0.5542 // kg/m3
#define RHO_AIR 1.225 // kg/m3
DEFINE_PROPERTY(saturation_temp, c, t)
// t: mixture thread
// c: cell variable
// Cell volume
real vol = C_VOLUME(c, t);
Thread *pt = THREAD_SUB_THREAD(t, 0); // Primary phase thread
Thread *st = THREAD_SUB_THREAD(t, 1); // Secondary phase thread
// Get the volume fraction of both phases
real vf_s = C_VOF(c, st);
real vf_p = 1 - vf_s;
// Get the pressure of the mixtureÂ
real p_mix = C_P(c, t);
// Get the operating pressure
real p_op = RP_Get_Real("operating-pressure");
// Primary phase density
real rho_p = C_R(c, pt);
// Get mass fractions in primary phase
real mf[2]; // to store mass fractions
Material *m = THREAD_MATERIAL(pt);
Material *sp = NULL;
int i; // Species index - 0 for water vapor and 1 for air
mixture_species_loop(m, sp, i)
mf[i] = C_YI(c, pt, i);
real p_w; // h20 pressure for cell
// If secondary phase only
if (vf_s == 1)
p_w = p_mix + p_op;
// If primary phase or mixture of phases
elseÂ
// Find the partial pressure of water vapour
// partial pressure = cell pressure * water mole fraction
// mass of primary phase in cell
real m_prim = rho_p * vol * vf_p;
// mass of water vapour and air in cell
real m_wv = mf[0] * m_prim;
real m_air = m_prim - m_wv;
// No of moles in water vapour and air
real N_wv = m_wv / MOLAR_MASS_WATER;
real N_air = m_air / MOLAR_MASS_AIR;
real N_total = N_wv + N_air;
// water vapour partial pressure
p_w = (C_P(c, t)+ p_op)* (N_wv / N_total);
// Calculate saturation temperature
real t_sat;
t_sat = (1730.63 / (10.196 - log10(p_w))) + 39.724;
return t_sat;
July 21, 2021 at 5:34 pmSurya Deb
Ansys EmployeeHello,
The first option (C_P(c, t)+ p_op)* (N_wv / N_total) is correct as it need to have the Absolute pressure information.
Also consider using Species Mass Transfer model if the evaporation/condensation is concentration driven.
Check this link [https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v212/en/flu_th/InterfaceSpeciesMassTransfer-3A72B96D.html?q=species%20mass%20transfer]
Regards SD
July 21, 2021 at 7:58 pmTryingMyBest1232
SubscriberThanks for the response! Do you see what else may be wrong with the code? The saturation temperatures it is returning are definitely not correct. The Saturation temperature being lower in places with more water vapour is a big giveaway but besides that, the variation is far too low.
July 22, 2021 at 9:16 amRob
Forum ModeratorIs water vapour the first species in the mixture list?
July 22, 2021 at 10:04 amTryingMyBest1232
SubscriberThank you! It is always the stupid mistakes!
July 22, 2021 at 10:06 amRob
Forum Moderator:) To make you feel better, remember that we've made (or seen) most of these before.
Viewing 5 reply threads- The topic ‘Saturation temperature UDF’ is closed to new replies.
5734
