July 31, 2020 at 6:14 pm
VivekKamble
Ansys EmployeeWhat is saturation and why and how does an electrical machine saturate?
CB
Ansys EmployeeWhen we say saturation in electrical machines we are speaking about magnetic saturation. If we increase the mmf of the magnet or if we increase the current in the coil, the flux density inside the iron of the machine is also increased. There is a limit beyond which magnetic flux density in the core will not increase proportional to the mmf. This limit is called magnetic saturation.
rtk
Ansys EmployeeHello,
How does it affect the electrical machine?
July 31, 2020 at 6:15 pm
CB
Ansys EmployeeHi @cblair,
When magnetic saturation sets in, the machine performance will not increase much even the magnetomotive force (MMF) is increased. You can understand these limits of the steel used in the machine by looking at the BH-curve of the steel. The knee point where the curve starts becoming parallel to X axis (H) is where the steel starts saturating
A saturated core requires more magnetizing current. This will increase I2R loss in the winding thus overheating the machine.
March 19, 2021 at 5:03 am
isaichaitanya
Subscriberhow to test magnetic saturation effect in pmsm using ansysnn -
June 30, 2022 at 3:45 am
kunaldugvekar
SubscriberYou can check magnetic flux densities & compare it with used material
s saturation levels. Also for a machine, a simple OCC test & voltage
s non-linearity can indicate saturation in the machine.Â
- The topic ‘Saturation in electrical machines’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3907
1414
1256
1118
1015
