November 8, 2023 at 4:32 pm
javat33489
SubscriberHi all.
I'm simulating drilling into a sandstone SPG ram.Drill - MAT_PLASTIC_KINEMATIC, sandstone - MOHR_COULUMB.
The units I use are: GPa, ms, kg, mm.
I use explicit analysis and the following settings:Â
I indicated the initial temperature in Celsius 22 degrees, is this correct or should it be indicated in Kelvin?
___
I waited for two entries in the d3plot and saw that the temperature on the SPG particle plate was very high, why?
Temperature graph on an SPG slab:
And how can this be fixed? Maybe you need thermal expansion cards?
November 9, 2023 at 3:36 pm
Ram Gopisetti
Ansys EmployeeHi
Can you let us know the solver used ?
Cheers.Â
November 9, 2023 at 4:38 pm
javat33489
SubscriberI use explicit analysis.
Version of the solver from the Ansys 2023 R1 package.
November 10, 2023 at 4:20 pm
November 12, 2023 at 6:19 pm
javat33489
SubscriberHelp please
November 20, 2023 at 7:26 pm
javat33489
SubscriberI need helpÂÂ
- The topic ‘Sandstone temperature problem’ is closed to new replies.
1306
