June 18, 2023 at 7:40 am
cool leaf
SubscriberWe face a issue when use Ansys do simulation.
we set the same simple testbench to load  cphy IBIS model ,but find they have different results in Primesim pro(Finesim ) and Ansys with same testbench.
- We can see the voltage change of the ABC single-ended in finesim is correct ,but in Ansys, The voltage has become very strange
- I hope you can provide technical support to help us solve this problem
Ansys without verilogA
June 19, 2023 at 4:02 pm
Aymen Mzoughi
Ansys EmployeeFor technical support you can open a case in Ansys Customer Support Space (ACSS) under customer.ansys.com
June 19, 2023 at 5:53 pm
Dan Dvorscak
Ansys EmployeeYes, if you are full Ansys customer, please open a support case so we can take a closer look. If not, we can try and give some more general advice here. First off, I don't see any finesim results, just Ansys Circuit waveforms. But I am also curious what IBIS models you are using here. I really have not seen much in the way of traditional IBIS models being used for MIPI c-phy as IBIS was never really intended to produce the 3 level output signaling that s-phy requires.Â
June 21, 2023 at 1:56 am
June 21, 2023 at 2:06 am
June 21, 2023 at 7:55 pm
Dan Dvorscak
Ansys EmployeeFor registration issue, please send email to ansys-communityhelp@ansys.com. They will be able to assist in portal registration. You can also reach out to your Ansys account manager and they may also be able to assist.Â
June 26, 2023 at 8:29 am
cool leaf
SubscriberHi @Dan Dv
I have this IBIS case that I need help from ansys engineer or AE.
There may be some NDA between synopsys and ansys, so we need set a meeting to fix it.
BR,
Zhishuang
June 26, 2023 at 1:44 pm
Dan Dvorscak
Ansys EmployeeHello Zhishuang,
That is not something that we can handle through this forum. Once you have opened a ticket in our system, one of our technical support engineers will be able to follow up with you on this regard.Â
Best regards,
-Dan
- The topic ‘same simple testbench to load cphy IBIS model ,but find they have different res’ is closed to new replies.
5849
