September 1, 2020 at 5:05 am
rrh
SubscriberI want to simulate the evaporation of micron size saline droplet in room temperature emitted from mouth using Fluent.nThe question is how to define the saline droplet in fluent? I defined multicomponent droplets (10um size, 90 wt.% water and 10 wt.% salt, the salt is created by changing the properties of another droplet material selected from the fluent material dataset), but there is no evaporation. When I use pure droplets (100 wt.% water), it works.nDoes anyone know how to resolve the issue? nThanks a lot!n -
September 1, 2020 at 6:45 am
DrAmine
Ansys EmployeeI hope you are letting the water content to evaporate: check your settings in the DPM Injection Panel.n -
September 1, 2020 at 4:53 pm
rrh
SubscriberThanks for your kindly reminder. I found the settings and it works. Thanks!n
- The topic ‘Saline droplet evaporation with DPM in Fluent?’ is closed to new replies.
