January 8, 2025 at 6:35 pm
l76124262
SubscriberI am currently designing a ring modulator and have successfully simulated the transmission under different bias voltages in FDTD. I noticed that the Optical Time Variant S-Parameter element in INTERCONNECT allows the import of S-parameters for modulators to simulate eye diagrams. However, in the official examples and FDTD’s sweep functionality, I only found methods for S-parameter sweeps of passive components.
Could you please advise: how can I perform an S-parameter sweep for a modulator in FDTD? Is there a way to incorporate bias voltage variations into the sweep process and generate the corresponding S-parameters for use in INTERCONNECT's Optical Time Variant S-Parameter element simulation? -
January 8, 2025 at 6:54 pm
Kirill
Forum ModeratorDear Subscriber,
This topic appears to be a duplicate of S parameter sweep for ring modulator and will be closed.
Thank you,
Kirill
- The topic ‘S parameter sweep for ring modulator’ is closed to new replies.
5824
