December 8, 2023 at 4:13 pm
Jan Stoebe
SubscriberHi,
I want to perform an harmonic quasi-magnetostatic simulation with Ansys Maxwell (i.e. eddy current solver type) and export the matrix data as Z-Parameter or S-Parameter data in Touchstone format. I have two coupled inductors with a magnetic core. I used one closed loop current terminal for each inductor as an excitation ("Current Excitation"). After performing the analysis, I get Z-Matrix Data which I can export, either from a "Create EddyCurrent Report/Data Table" or from "Results/Solution Data/Matrix/Export/Export Solution". I cannot find a way to export tthe data in Touchstone format though. Is this possible?
Thanks in advance,
Jan
December 12, 2023 at 7:32 pm
HDLI
Ansys EmployeeHello Jan,
   To build Touchstone format file for Marix, you need to set "Frequency sweep" in Setup and have Matrix. After completing simulation, we should find "Network Data Explorer" by right clicking Setup. Please click this operation to export broadband and change file format to Touchstone. Â
HDLI
January 26, 2024 at 1:15 pm
- The topic ‘S-Parameter Export from Ansys Maxwell Eddy Current Simulation’ is closed to new replies.
6795
1332
1152
