April 18, 2019 at 2:23 pm
philo
SubscriberMaterial Properties
Brake Pad
Thermal conductivity, k[W/m0C]
26
Density, ρ [kg/m3]
1800
Specific heat, C [J/Kg 0C]
880
Poisson’s ratio, v
0.3
Thermal expansion, α [10-6/C]
0.3
Elastic modulus, E [GPa]
50.2
I have the above properties of a brake pad material which are not inbuilt in the engineering data sources. How do i get results of fatigue when the material isn't already in ANSYS workbench given that i don't have the S_N curves of the material?.
April 19, 2019 at 12:30 am
peteroznewman
SubscriberYou can perform your own lab experiments to collect data to construct SN curves or you can find data in the literature.
April 25, 2019 at 8:52 pm
philo
Subscriberunfortunately i haven't been able to come across brake pad materials with those details, would you be kind as to share some if you know any?
April 25, 2019 at 9:00 pm
peteroznewman
SubscriberI have no data on brake pad materials but I have collected my own SN data in lab tests for other materials.
- The topic ‘S-N curve of brake pad material’ is closed to new replies.
3175
1019
957
858
798
