April 30, 2024 at 11:07 pm
mctom0518
SubscriberI am having an issue when I run Ansys Workbench 2022R2 on WSL 2 (Windows Subsystem for Linux 2) when connecting to a cluster via SSH. When I execute runwb2 in the Terminal, I get the following message:
=================================================================Native Crash Reporting=================================================================Got a SIGABRT while executing native code. This usually indicatesa fatal error in the mono runtime or one of the native librariesÂused by your application.=================================================================Â=================================================================Native stacktrace:=================================================================0x4a5624 - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x4a598c - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x454498 - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x4a4c8f - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x7fed58433630 - /lib64/libpthread.so.0 : (null)0x7fed57e74387 - /lib64/libc.so.6 : gsignal0x7fed57e75a78 - /lib64/libc.so.6 : abort0x7fed4f300833 - /u/local/apps/ansys/2022R2/v222/Framework/bin/Linux64/libstdc++.so.6 : (null)0x7fed4f3069a6 - /u/local/apps/ansys/2022R2/v222/Framework/bin/Linux64/libstdc++.so.6 : (null)0x7fed4f3069e1 - /u/local/apps/ansys/2022R2/v222/Framework/bin/Linux64/libstdc++.so.6 : (null)0x7fed4f306c13 - /u/local/apps/ansys/2022R2/v222/Framework/bin/Linux64/libstdc++.so.6 : (null)0x7fed4f302767 - /u/local/apps/ansys/2022R2/v222/Framework/bin/Linux64/libstdc++.so.6 : (null)0x7fed4f327574 - /u/local/apps/ansys/2022R2/v222/Framework/bin/Linux64/libstdc++.so.6 : (null)0x7fed4f319f7c - /u/local/apps/ansys/2022R2/v222/Framework/bin/Linux64/libstdc++.so.6 : _ZNSt6locale5_ImplC2EPKcm0x7fed4f31ae32 - /u/local/apps/ansys/2022R2/v222/Framework/bin/Linux64/libstdc++.so.6 : _ZNSt6localeC1EPKc0x7fecde6607e7 - /u/local/apps/ansys/2022R2/v222/Framework/bin/Linux64/libComponentSystem.so : (null)0x7fed58f779c3 - /lib64/ld-linux-x86-64.so.2 : (null)0x7fed58f7c59e - /lib64/ld-linux-x86-64.so.2 : (null)0x7fed58f777d4 - /lib64/ld-linux-x86-64.so.2 : (null)0x7fed58f7bb8b - /lib64/ld-linux-x86-64.so.2 : (null)0x7fed58640fab - /lib64/libdl.so.2 : (null)0x7fed58f777d4 - /lib64/ld-linux-x86-64.so.2 : (null)0x7fed586415ad - /lib64/libdl.so.2 : (null)0x7fed58641041 - /lib64/libdl.so.2 : dlopen0x6e766a - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : mono_dl_open0x5d82f8 - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x5d851c - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x5d8e3c - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x5da0d9 - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x5e5fcd - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x4e4ebc - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x4aad6f - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x4accc2 - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x4222b0 - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x457bf6 - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x458730 - /u/local/apps/ansys/2022R2/v222/Tools/mono/Linux64/bin/mono : (null)0x41b86387 - UnknownÂ=================================================================Telemetry Dumper:=================================================================Pkilling 0x7fed57e3d700 from 0x7fed5915f780Entering thread summarizer pause from 0x7fed5915f780Finished thread summarizer pause from 0x7fed5915f780.ÂWaiting for dumping threads to resumeÂ=================================================================Basic Fault Address Reporting=================================================================Memory around native instruction pointer (0x7fed57e74387):0x7fed57e74377 48 63 d7 48 63 f6 48 63 f9 b8 ea 00 00 00 0f 05 Hc.Hc.Hc........0x7fed57e74387 48 3d 00 f0 ff ff 77 1e f3 c3 0f 1f 80 00 00 00 H=....w.........0x7fed57e74397 00 85 c9 7f db 89 c8 f7 d8 81 e1 ff ff ff 7f 0f ................0x7fed57e743a7 44 c6 89 c1 eb ca 48 8b 15 9c 0a 39 00 f7 d8 64 D.....H....9...dÂ=================================================================Managed Stacktrace:================================================================= at <0xffffffff> at Ans.Program.Runtime:Initialize <0x00a5b> at Ans.Program.ExecutableBase:Run <0x00057> at Ans.Program.ExecutableBase:DoMain <0x004e3> at Ans.Program.Executable:Main <0x0003f> at :runtime_invoke_int_object <0x00085>=================================================================ÂI also get a mono_crash .BLOB and .JSON files as well.ÂÂThank you for the help!Â
May 1, 2024 at 6:46 pm
mctom0518
SubscriberI was actually able to fix the issue by updating and resetting the locale settings on WSL: In a WSL Terminal: (1) sudo locale-gen en_US.UTF-8 (2) sudo update-locale LANG=en_US.UTF-8 In a Powershell Terminal with Admin Privileges: (3) wsl --shutdown
- The topic ‘Running Workbench on WSL 2’ is closed to new replies.
