February 22, 2023 at 9:01 am
pavankonchada123
SubscriberHi Ansys Team,
     I am able to run the ansys static structural with journal commands, but I want to run 2 to 3 systems in a sequential manner. So how can I modify my journal file so that one system is run will be followed by next system run.
SetScriptVersion(Version="22.2.192")
template1=GetTemplate(TemplateName="Static Structural",Solver="ANSYS")
system1=template1.CreateSystem()
geometry1=system1.GetContainer(ComponentName="Geometry")
geometry1.SetFile(FilePath="C:/Users/cadfem/Downloads/Geom.agdb")modelComponent1 = system1.GetComponent(Name="Model")
modelComponent1.Refresh()
model1 = system1.GetContainer(ComponentName="Model")
model1.Edit(Interactive=False)
DSscript = open("D:scrt.py", "r")
DSscriptcommand=DSscript.read()
DSscript.close()
model1.SendCommand(Language='Python', Command = DSscriptcommand)
system2=template1.CreateSystem()
geometry2=system2.GetContainer(ComponentName="Geometry")
geometry2.SetFile(FilePath="C:/Users/cadfem/Downloads/Geom.agdb")modelComponent2 = system2.GetComponent(Name="Model")
modelComponent2.Refresh()
model2 = system2.GetContainer(ComponentName="Model")
model2.Edit(Interactive=False)
DSscript.close()
model2.SendCommand(Language='Python', Command = DSscriptcommand)Â
On executing the above journal both system are running at a time, Please help
Can the GetSimulationResultFile() helps the journal file to wait until one system run is done
February 24, 2023 at 10:45 am
Aniket Chavan
Forum ModeratorHi,
I am not sure what are the contents of the D:\script.py but you can remove all the solve commands from it, and update the system one by one in the Workbench page to achieve what you want.
You can also record this operation in journal file.
-Aniket
February 24, 2023 at 1:12 pm
pavankonchada123
SubscriberScript file includes procedure such as imorting,assigning boundaries and post processing. And if I record the journal file and read it all the systems will try to run at same time right. I want to get them updated in sequential format (like update all design points) in workbench.
February 24, 2023 at 1:15 pm
pavankonchada123
SubscriberSo any advice that how I can achieve this with reading script file for each system and runing the systems sequentially
February 24, 2023 at 2:24 pm
Aniket Chavan
Forum ModeratorHi like I mentioned, exclude all the commands that update or solve the project. You can add all the BCs and post-processing objects only (do not solve or evaluate anything in the DSscript)
i.e. after model1.SendCommand(Language='Python', Command = DSscriptcommand)
you may need something on the lines of:
resultsComponent1 = system1.GetComponent(Name="Results")
resultsComponent1.Update(AllDependencies=True)and then you will continue with second system in similar fashion. So the first system will update first and then second will be updated later from workbench page.
-Aniket
February 24, 2023 at 2:34 pm
pavankonchada123
SubscriberHI Aniket,
With out manual intervention I want all the systems through single journal file. But wnen I do this all the system are running at same time. Is there any method to stop workbench from going to second system until first system is completed (automatically)
February 25, 2023 at 11:45 am
Aniket Chavan
Forum ModeratorThe code in the journal is executed line by line. So until
is executed fully, it will NOT go toÂ
resultsComponent2.Update(AllDependencies=True)
for a better understanding of this, remove the sendcommand from your code and try updating the model. You will see the mesh of the first system is generated first (obviously it won't solve after that due to lack of BCs) and the mesh of the second system is generated AFTER the generation of the first system. You can add print() messages in your code to verify that.
-Aniket
- The topic ‘Running the system sequentially’ is closed to new replies.
5669
1890
1419
1304
