March 17, 2024 at 9:02 am
gangolu
SubscriberHi,Â
I need to automate running simulations and extracting results without manually opening each simulation. I'm using LS-DYNA to model blast loading on steel columns. Can someone provide a solution for this, preferably using MATLAB?
March 18, 2024 at 1:09 pm
Armin
Ansys EmployeeHi Jaswanth,
If you're using LS-PrePost for post-processing your model, it is possible to use macro commands to automate the process. Please look up online for "LS-Prepost Command Line Interface" and you should be able to find some resources online.
https://lsdyna.ansys.com/command/
- The topic ‘Running more simulations at a time and extract results without manually opening’ is closed to new replies.
