July 18, 2019 at 3:22 pm
ahkumar
SubscriberDear Ansys support,
We have Ansys 19.1 installed on our cluster and every time I run ansysedt "first-time configuration" is rerun. A user could get a random compute node for their runs. Given the installation is on a shared folder and users home directory are same across the cluster we get the attached error.
Can you please help resolving this issue. How can I suppress this first time configuration for a user if he/she has already run and initialized on another node?
Please let me know if you need additional information.
Best Regard,
Amit
July 18, 2019 at 3:24 pm
ANSYS_MMadore
Forum ModeratorHello Amit,
You can set this variable to avoid the check. ANS_NODEPCHECK=1
Thank you,
Matt -
July 18, 2019 at 4:41 pm
ahkumar
SubscriberThank you!! That did it.
July 18, 2019 at 4:44 pm
ahkumar
SubscriberAlthough it does not tell me why it keeps re-running the first-time configuration. If there is a fix for that then I don't have to instruct users to use this variable.Â
Would love to hear if there is another implicit solution.Â
Best Regards,
Amit
July 19, 2019 at 6:10 pm
tsiriaks
Ansys EmployeeHi Amit,
Can you set the environment variable ANS_NODEPCHECK=1 in the bash profile file for all users , so it gets set each time they login ?
Thanks,
Win
- The topic ‘Running first-time configuration, everytime’ is closed to new replies.
3862
1414
1220
1118
1015
