February 24, 2023 at 10:55 am
194106015
SubscriberHello, Can someone help with this,
When i am trying to run Chemkin through Fortran in Linux platfrom( Ubuntu), I am getting error for the standard example files also. Below is the terminal o/p when i run the make file
neeraj@HP-Z2:~/Desktop/Neeraj/Project_in_Linux/Code/sample_apps_f77/sksample$ make -f sksample_unix.mak
Compiling sksample_driver.f
ifort -assume noold_maxminloc -fPIC -O3 -m64 -D_LINUXX8664 -DUSE_XERCES_2_8 -qopenmp -mkl=sequential -I. -Iunix -I../unix -I.. -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/include/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/user_routines -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/source/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/source/solvers/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/source/multiPhase -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/kinetics/API  -I/include -I/include/xercesc -I/source/encryption -nofor_main -fpp  -I/opt/intel/oneapi/mkl/2021.4.0/include/intel64/lp64 -I/opt/intel/oneapi/mkl/2021.4.0/include  -c -o sksample_driver.o sksample_driver.f
ifort: command line remark #10412: option '-mkl=sequential' is deprecated and will be removed in a future release. Please use the replacement option '-qmkl=sequential'
ifort: command line warning #10434: option '-nofor_main' use with underscore is deprecated; use '-nofor-main' instead
Compiling sksample.f
ifort -assume noold_maxminloc -fPIC -O3 -m64 -D_LINUXX8664 -DUSE_XERCES_2_8 -qopenmp -mkl=sequential -I. -Iunix -I../unix -I.. -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/include/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/user_routines -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/source/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/source/solvers/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/source/multiPhase -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/kinetics/API  -I/include -I/include/xercesc -I/source/encryption -nofor_main -fpp  -I/opt/intel/oneapi/mkl/2021.4.0/include/intel64/lp64 -I/opt/intel/oneapi/mkl/2021.4.0/include  -c -o sksample.o sksample.f
Creating /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/bin/sksample
ifort -mkl=sequential -fpp -I. -Iunix -I../unix -I.. -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/include/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/user_routines -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/source/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/source/solvers/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/source/multiPhase -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/kinetics/API  -I/include -I/include/xercesc -I/source/encryption -L. -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/bin/ -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/ -o /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/bin/sksample sksample_driver.o sksample.o -L. -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/bin/ -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/ /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/chemkin_xml.a  /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/restart_xml.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/chemkin_zip.a  /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/ckptm.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/surface_chemkin.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/chemkin.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/solvers.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib//libmkl_blas95_lp64.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib//libmkl_lapack95_lp64.a  -lpthread -lm -mkl=sequential /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/user_routines.a -lxerces-c-3.2 -lckzip -lckunzip -lCKGlobalMechanism  -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/bin/ -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/lib/ -qopenmp -lpthread -lrt -lstdc++Â
Running sksample
/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/bin/sksample < sksample.inp > sksample.out
/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/bin/sksample: error while loading shared libraries: libxerces-c-3.2.so: cannot open shared object file: No such file or directory
make: *** [sksample_make.inc:55: sksample.out] Error 127 -
February 27, 2023 at 11:00 pm
jcooper
Ansys EmployeeHi Neeraj:
The Chemkin API document details some preparation steps for Chemkin compilation on Unix. I would suggest going over these if you haven't already. The primary issue here seems to be a missing library, however:
The Ansys Chemkin-Pro installation file include/chemkin_make_unix.inc (include\chemkin_make_pc.inc for PC), defines make (nmake) macros for required compile and link flags, as well as library names and locations. You MUST use this installation file when compiling your own code to ensure that the compiler directives are consistent with those used in Chemkin-Pro, and to avoid errors during linking. A user makefile can set a few additional macros to compile and link a program; the user macro, CKROOT for example, must be defined as the root location of your Chemkin-Pro installation. This should be included in the make file as below:
(Please see the Chemkin installation test files in ...ANSYS Inc\v231\reaction\chemkinpro.win64\samples\chemkin_cfd_api\test01 for another test program that uses the make file below.)
# This make file is used to build the Chemkin chemkin_cfd_api sample.ALL : chemkin_cfd_api.out
# relative path to the CHEMKIN install directory
CKROOT Â = ../../..# global CHEMKIN make directives
include $(CKROOT)/include/chemkin_make_unix.incALL_OBJS = $(CKROOT)/samples/chemkin_cfd_api/cpp_interface/KINetics_Driver$(OBJECT) $(CKROOT)/samples/chemkin_cfd_api/cpp_interface/KINeticsLibrary$(OBJECT)
ALL_LIBS = $(CPPF77_LIBFLAGS) -lKINetics -lkinetics_usr $(SAX_ONLY_LIBFLAGS) $(CPPF77_SYSTEM_LIBS)
CHEMKININCLUDE = -I. -I$(CKROOT)/include/ -I$(CKROOT)/samples/chemkin_cfd_api/API/
# make directives for this problem
include chemkin_cfd_api_test01_make.incchemkin_cfd_api.out   : chemkin_cfd_test$(EXE)
  $(CK_DISPLAY) Running chemkin_cfd_test
  .$(SLASH)chemkin_cfd_test$(EXE) > chemkin_cfd_api.outI hope this helps.
Best Regards,
Judy
February 28, 2023 at 6:12 am
194106015
SubscriberHello Judy, Thanks for the response.
I have gone through the Chemkin API document and have updated the CKROOT path.
I am trying to run a sample example problem provided in samples provided in .
/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro_linuxx8664/samples/sample_apps_f77
There in make file i have to just update the CKROOT, and i have done that.
If we see my o/p which i posted, it is compiling properly ksample_driver.f, sksample.f etc
It has problem when its running sksample in line
here sksample is an exe file ,
in error msg
here i think its considering sksample as an folder. The shared object libxerces-c-3.2.so is present inside /.../chemkinpro_linuxx8664/bin but it is searching inside sksample folder. Thats what i think is causing issue.
Thanks in advance
Regards
Neeraj
February 28, 2023 at 5:01 pm
jcooper
Ansys EmployeeHI Neeraj:
You can try moving a copy of the file into cksample to see if it addresses the problem.Â
The make file is pretty old. Can you please send me the output from the compile and link steps?
Thanks,
Judy
March 1, 2023 at 6:43 am
194106015
SubscriberHello Judy, Thaks for the response.
Regarding moving a copy of file to cksample: I tried that but cant because cksample is a exe file present inside ../bin . This exe file is called to run the program , i am unable to create a folder cksample inside bin as already with same name an exe file is there.
Output from the terminal :
~/Desktop/Neeraj/Project_in_Linux/Code/sample_apps_f77/sksample$ make -i -f sksample_unix.mak
ifort -assume noold_maxminloc -fPIC -O3 -m64 -D_LINUXX8664 -DUSE_XERCES_2_8 -qopenmp -mkl=sequential -I. -Iunix -I../unix -I.. -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/include/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/user_routines -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/source/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/source/solvers/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/source/multiPhase -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/kinetics/API  -I/include -I/include/xercesc -I/source/encryption -nofor_main -fpp  -I/opt/intel/oneapi/mkl/2021.4.0/include/intel64/lp64 -I/opt/intel/oneapi/mkl/2021.4.0/include  -c -o sksample_driver.o sksample_driver.f
ifort -assume noold_maxminloc -fPIC -O3 -m64 -D_LINUXX8664 -DUSE_XERCES_2_8 -qopenmp -mkl=sequential -I. -Iunix -I../unix -I.. -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/include/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/user_routines -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/source/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/source/solvers/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/source/multiPhase -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/kinetics/API  -I/include -I/include/xercesc -I/source/encryption -nofor_main -fpp  -I/opt/intel/oneapi/mkl/2021.4.0/include/intel64/lp64 -I/opt/intel/oneapi/mkl/2021.4.0/include  -c -o sksample.o sksample.f
Creating /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/bin/sksample
ifort -mkl=sequential -fpp -I. -Iunix -I../unix -I.. -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/include/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/user_routines -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/source/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/source/solvers/ -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/source/multiPhase -I/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/kinetics/API  -I/include -I/include/xercesc -I/source/encryption -L. -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/bin/ -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/ -o /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/bin/sksample sksample_driver.o sksample.o -L. -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/bin/ -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/ /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/chemkin_xml.a  /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/restart_xml.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/chemkin_zip.a  /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/ckptm.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/surface_chemkin.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/chemkin.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/solvers.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib//libmkl_blas95_lp64.a /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib//libmkl_lapack95_lp64.a  -lpthread -lm -mkl=sequential /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/user_routines.a -lxerces-c-3.2 -lckzip -lckunzip -lCKGlobalMechanism  -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/bin/ -L/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/lib/ -qopenmp -lpthread -lrt -lstdc++Â
Running chem
/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/bin/chem -i chem.inp -o chem.out
Licenses Released
Running surf
/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/bin/surf -i surf.inp -o surf.out
Licenses Released
Running sksample
/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/bin/sksample < sksample.inp > sksample.out
/home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664/bin/sksample: error while loading shared libraries: libxerces-c-3.2.so: cannot open shared object file: No such file or directory
make: [sksample_make.inc:55: sksample.out] Error 127 (ignored)sksample_unix.mak file has
#***********************************************************************BEGIN-HDR
#  © 2022 ANSYS, Inc.  Unauthorized use, distribution, or duplication is prohibited.
# Â $Header: /chemkin/4.1/prebuild/samples/sample_apps_cpp/sksample/sksample_unix.mak 55 Â Â 12/21/05 8:46p Frupley $
# Â $NoKeywords: $
#***********************************************************************END-HDR
# This make file is used to build the Chemkin SKSAMPLE sample.ALL : sksample.out
CKROOT Â = /home/neeraj/Documents/Ansys_inst/ansys_inc/v222/reaction/chemkinpro.linuxx8664# global CHEMKIN make directives
# first part of the Fortran link command
ifdef USE_INT64
LINK Â = $(FOR) $(FFLAGS) $(LDFLAGS) $(EXENAME)
else
LINK Â = $(FOR) -mkl=sequential -fpp $(CHEMKININCLUDE) $(LDFLAGS) $(EXENAME)
endif# make directives for this problem
include sksample_make.inc----------------------------------------------------------------------------
sksample_make.inc file has
# Â $Header: /chemkin/4.3/prebuild/samples/sample_apps_f77/sksample/sksample_make.inc 16 Â Â 5/16/08 9:51a Frupley $
# Â $NoKeywords: $
# This make file is used to build the Chemkin SKSAMPLE sample.#
# targets to build
#SKSAMPLE_OBJS = sksample_driver$(OBJECT) sksample$(OBJECT)
$(CHEMKINBIN)sksample$(EXE) Â : $(SKSAMPLE_OBJS)
  $(CK_DISPLAY) Creating $@
  $(LINK) $? $(ALL_LIBRARIES)
  $(REMOVE) $(INTERMEDIATE_FILES)#
# run the programs
# Â Run gas-phase Chemkin interpreter
# Â Â the input file is 'chem.inp'
# Â Â the output file is 'chem.out'
chem.asc   : $(CHEMKINBIN)chem$(EXE) therm.dat chem.inp
  $(REMOVE) $(CHEM_OUTPUTS)
  $(CHEMKINBIN)chem -i chem.inp -o chem.out#*************************************
# Â Run Surface Chemkin interpreter
# Â Â the input file is 'surf.inp'
# Â Â the output file is 'surf.out'
surf.asc   : $(CHEMKINBIN)surf$(EXE) chem.asc therm.dat surf.inp
  $(CK_DISPLAY) Running surf
  $(REMOVE) $(SURF_OUTPUTS)
  $(CHEMKINBIN)surf -i surf.inp -o surf.out#*************************************
# Â Run Sksample
# Â Â the input file is 'sksample.inp'
# Â Â the output file is 'sksample.out'
SKSAMPLE_OUTPUTS = sksample.out
sksample.out  : $(CHEMKINBIN)sksample$(EXE) surf.asc sksample.inp chemkindata.dtd
  $(CK_DISPLAY) Running sksample
  $(REMOVE) $(SKSAMPLE_OUTPUTS)
  $(CHEMKINBIN)sksample < sksample.inp > sksample.outALL_EXES   = $(CHEMKINBIN)sksample$(EXE)
CLEAN Â Â Â :
  $(REMOVE) $(EXTRA_CLEAN) $(ALL_EXES) $(ALL_LIBS) $(SKSAMPLE_OUTPUTS)----------------------------------------------------------------------------
February 28, 2023 at 6:30 pm
jcooper
It is possible that the environment is setup incorrectly, so that Chemkin doesn't know where to look for the file. The default is in the working folder.
Please try source either chemkinpro_setup.csh or chemkinpro_setup.ksh in ansys_inc\v222\reaction\chemkinpro.linuxx8664\bin directory. This will set up the necessary environment for running Chemkin on Linux.
Best Regards,
Judy
March 1, 2023 at 9:43 am
194106015
SubscriberHello Judy.
Thanks for the reply. You are correct
When we are sourcing the .ksh file in .bashrc, it was not able to source the .ksh file properly because of the improper folder name chemkinpro.linuxx8664. This folder is generated automatically while installation. I changed the folder name to chemkinpro_linuxx8664, then updated this folder name where ever required in scripts and now its working fine.
Thanks again for the help and support
Regards
Neeraj
- The topic ‘Running Chemkin through fortran’ is closed to new replies.
5674
1890
1419
