July 4, 2024 at 7:55 am
avdheshkumar.gola
SubscriberHi, I am trying to solve a static strutural analysis which uses the solution from Steady State Thermal analysis. This means Thermal analysis needs to be solved first and then the solution is used as "imported loads" in static strutural analysis. How can I solve this on HPC in a single run?Â
July 8, 2024 at 3:38 pm
Ashish Khemka
Forum ModeratorHi Avdhesh,
You can create a linked thermal structural analysis system first and then update the project to run in HPC.
Ashish Khemka
- The topic ‘Run submission on HPC to solve thermal and then structural analysis in same run’ is closed to new replies.
1885
1403
1257
