Systems
Systems
Topics related to Twin Builder, medini analyze, VRXPERIENCE and more.
Run Mechanical in parallel
    • guimilan
      Hi everyone,
      I'm having issue running ANSYS Mechanical on multiple cores. I'm running on a cluster (operating system: linux) and I have no access to the graphic interface of ANSYS. I have tried to use the -np #cores (and the -dis -np #cores) command in the terminal, but I get the error "-bash, command not found".
      Is there any command line to type in the terminal that does the same as Tool > Solver Settings > Advanced > ... in Mechanical app?
      Thanks for helping.
    • Sandeep Medikonda
      Can you provide a snapshot of  the problems you are experiencing?
  • The topic ‘Run Mechanical in parallel’ is closed to new replies.
