October 8, 2024 at 8:51 am
Christoph Hollweck
SubscriberHello everyone,
Currently, LS-DYNA is running only in combination with the LSTC_FILE and the LSTC license. Since our LSTC license is limited to just one CPU, I would like to switch to the ANSYS license.The current LSTC_FILE contains the following:
#LICENSE_TYPE: network#LICENSE_SERVER: ourservernameWhen I change it to:
#LICENSE_TYPE: ANSYS#LICENSE_SERVER: ourservernamethe LSTC license is still being used.
What do I need to write in the LSTC_FILE to ensure that the ANSYS license is used instead?
Thank you!
Christoph
October 9, 2024 at 2:02 pm
igandiko
Ansys EmployeeI would try removing LSTC_FILE and unset the env variables. To use LS-DYNA solver with Ansys license, you only need to define the below env, no need to define the LSTC_LICENSE_SERVER.Â
export LSTC_LICENSE=Ansys
Note that you will need any additional env you generally set for Ansys license, such as ANSYSLMD_LICENSE_FILE.
October 17, 2024 at 3:16 am
haridas.pt
Subscriber@igandiko Will this allow me to use Ansys HPC Pack to increase the parallel cores for an LSDYNA run?
5899
1306
