TAGGED: ansys-autodyn, material-property, rc-beam, rubber
March 6, 2024 at 2:12 pm
ahmed.taher
SubscriberHello,
I am trying to use "Rubber1" material in strengthening an RC column to resist blast load using AutoDyn GUI. this message appears when I use it to fill a 5 cm layer part as "strengthening".
Side note: I am using Lagrange model for the Rubber1 material.
I figured that the EOS of the material is hyperplastic which is already set in the material list in the Autodyn (predefined material model), How do I use it proberly? I tried Sand and it went very well. I want to use Rubber material but I am not sure what I need to do. Also, if there is another EOS for Rubber, is there any reference in which setting values for it such as "bulk modulus, etc..."?
Thanks in advance, -
March 28, 2024 at 10:35 am
ashish.khemka
Forum ModeratorHi Ahmed,
Unfortunately this question is beyond the scope for ANSYS employees to answer on a public forum, so hopefully other users can chime in.
Ashish Khemka
- The topic ‘Rubber1 material define’ is closed to new replies.
