October 26, 2021 at 11:43 pm
komal.gada
SubscriberOctober 27, 2021 at 7:24 pmGeorge Karnos
Ansys EmployeeCan you post the contents of the RSM Job Report as we are not permitted to open files.
Many Thanks!
October 27, 2021 at 8:02 pmkomal.gada
SubscriberI get an error saying character too long when I try and paste the entire RSM job report.
Anyhow, pasting few of the lines:
Current Directory: /net/hpc.staas.its.csulb.edu/research/COE/CEERS/Komal/rsmstaging/aifib4en.jcd (10/25/2021 3:45:27 PM)
Running command: /ansys_inc/v201/SEC/SolverExecutionController/runsec.sh
Redirecting output toNone
Final command arg list : ['/ansys_inc/v201/SEC/SolverExecutionController/runsec.sh']
Running Process
Running Solver : /ansys_inc/v201/fluent/bin/fluent --albion --run --launcher_setting_file "fluentLauncher.txt" --fluent_options "-gu -driver null -driver null-workbench-session -i \"SolutionPending.jou\"-mpi=intel -t128 -cnf=hosts.txt -ssh"
/ansys_inc/v201/fluent/fluent20.1.0/bin/fluent -r20.1.0 --albion --run --launcher_setting_file fluentLauncher.txt
Warning:DISPLAY environment variable is not set.
Graphics and GUI will not operate correctly
without this being set properly.
bash: /ansys_inc/v201/fluent/fluent20.1.0/multiport/mpi/lnamd64/intel/bin/pmi_proxy: No such file or directory
Inquiring for files by Tag: [progress]
No files transferred.
No files transferred. (10/25/2021 3:49:24 PM)
Then the message keeps continuing with "Inquiring for files by Tag: [progess] No files transferred." Until it hits the walltime specifies or I manually cancel the job.
November 1, 2021 at 1:14 pmHunter Wang
Ansys EmployeeFound
AWP_ROOT201=/ansys_inc/v201
Check If /ansys_inc/v201 is available from all compute nodes. AWP_ROOT201 should be set to a global shared directory which is available for all compute nodes.
November 1, 2021 at 5:22 pmkomal.gada
SubscriberYes, I have set AWP_ROOT201=/ansys_inc/v201 globally on all nodes.
November 11, 2021 at 4:07 amkomal.gada
SubscriberI had to reinstall Ansys 2020R1 on Linux server and now the error is gone.
Viewing 5 reply threads- The topic ‘RSM job hangs idle until manually terminated or walltime runs out’ is closed to new replies.
5794
