June 1, 2023 at 11:08 am
Alex Pritchard
SubscriberI have been trying to use the RSM tool to connect to my universities high performance computing facilities. So far I can get the test tool in the RSM configuration to successfully connect, write and submit the test. After this the test fails stating 'AWP_ROOT231 is not set on cluster compute node'. Any idea's on what I can try to resolve this would be really useful!
Job report as follows:
            Ansys Job Report
  Job Name:  K2-lowpri Test Job
  Owner:  ADS\3057254
  Submitted:  01/06/2023 11:44:45
  Priority: Â
  Server:  Kelvin2 HPC
  Queue:  K2-lowpri
  Final Status:  Failed
  Job Log:RSM Version: 23.1.0.0, Build Date: 18/11/2022 18:15:44
RSM File Version: 23.1.0.0+Branch.releases-release-23.1.Sha.1309ddcecdb7e4a72b8bdc4bae53e2b96fffead9
RSM Library Version: 23.1.0.0
  Type: SERVERTEST
  Client Directory: C:\Users\3057254\AppData\Local\Temp\RsmConfigTest\jcsf1egx.5dg
  Client Machine: MAE-139825
  Queue: K2-lowpri [Kelvin2 HPC, k2-lowpri]
  Template: SERVERTEST
Cluster Configuration: Kelvin2 HPC [kelvin2.qub.ac.uk]
  Cluster Type: SLURM
  Custom Keyword: blank
  Transfer Option: External
  External Storage Type: SSH-SCP
  Staging Directory: /mnt/scratch2/users/3057254
  Delete Staging Directory: False
  Local Scratch Directory: /mnt/scratch2/users/3057254
  Platform: Linux
  Using External Communication Protocol
    Remote Account: 3057254
  Cluster Submit Options: blank
  Normal Inputs: [*,commands.xml,*.in]
  Cancel Inputs: [-]
  Excluded Inputs: [-]
  Normal Outputs: [*]
  Failure Outputs: [-]
  Cancel Outputs: [-]
  Excluded Outputs: [-]
  Inquire Files:
   normal: [*]
   inquire: [*.out]
Submission in progress...
Runtime Settings:
  Job Owner: ADS\3057254
  Submit Time: 01 June 2023 11:44
  Alternate Platform Directory: /mnt/scratch2/users/3057254/ua112kx2.5j2
Transferring file: commands.xml        | 2 kB |  2.5 kB/s | ETA: 00:00:00 | 100%
Transferring file: tEst WiTh sPaCe.in     | 0 kB |  0.0 kB/s | ETA: 00:00:00 | 100%
Transferring file: tEsT.in          | 0 kB |  0.0 kB/s | ETA: 00:00:00 | 100%
2.68 KB, 10.9 sec (.25 KB/sec)
JobType is: SERVERTEST
Final command platform: Linux
RSM_PYTHON_HOME=C:\Program Files\ANSYS Inc\v231\commonfiles\CPython\3_7\winx64\Release\python
RSM_HPC_JOBNAME=RSMTest
Distributed mode requested: True
RSM_HPC_DISTRIBUTED=TRUE
Running 4 commands
Job working directory: C:\Users\3057254\AppData\Local\Temp\RsmConfigTest\jcsf1egx.5dg
Number of CPU requested: 1
AWP_ROOT231=C:\Program Files\ANSYS Inc\v231
Testing writability of working directory...
If you can read this, file was written successfully to working directory
Writability test complete
Checking queue k2-lowpri exists ...
Job will run locally on each node in: /mnt/scratch2/users/3057254/ua112kx2.5j2
Transferring file: control_9a89de12-98e4-4a7 | 3 kB | Â 3.6 kB/s | ETA: 00:00:00 | 100%
Transferring file: clusterjob_9a89de12-98e4- | 1 kB | Â 1.6 kB/s | ETA: 00:00:00 | 100%
5.35 KB, 5.79 sec (.92 KB/sec)
JobId was parsed as: 11710003
Job submission was successful.
Trying to download diagnostic output files.
Transferring file: stdout_9a89de12-98e4-4a79 | 0 kB | Â 0.1 kB/s | ETA: 00:00:00 | 100%
Transferring file: exitcode_9a89de12-98e4-4a | 0 kB | Â 0.0 kB/s | ETA: 00:00:00 | 100%
AWP_ROOT231 is not set on cluster compute node.
ClusterJobs Command Exit Code: 1000
Trying to cleanup diagnostic files.
No files to transfer. -
June 9, 2023 at 12:47 pm
MangeshANSYS
Ansys EmployeePlease see this documentation page for setting the variable
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/wb_rsm/wb_nx_path_conf_426.htmlÂ
June 13, 2023 at 6:36 pm
Alex Pritchard
SubscriberHello Mangesh. Thank you for the reply! I followed the instructions and I now get the error message 'AWP_ROOT231 directory does not exist from execution node.' Any ideas on what to try next?
Error report now as follows:
Job Name: Sandbox Test Job
  Type: SERVERTEST
  Client Directory: C:\Users\3057254\AppData\Local\Temp\RsmConfigTest\ql5lifuh.gok
  Queue: Sandbox [Kelvin2 HPC, sandbox]
  Cluster Type: SLURM
  Delete Staging Directory: True
  Platform: Linux
  Cancel Inputs: [-]
  Normal Outputs: [*]
  Cancel Outputs: [-]
  Inquire Files:
   normal: [*]
   inquire: [*.out]
Runtime Settings:
  Submit Time: 13 June 2023 19:29
  Alternate Platform Directory: /mnt/scratch2/users/3057254/ppnerzs3.jfs
2.68 KB, 3.6 sec (.74 KB/sec)
Running 4 commands
Job working directory: C:\Users\3057254\AppData\Local\Temp\RsmConfigTest\ql5lifuh.gok
Checking queue sandbox exists ...
Job will run locally on each node in: /mnt/scratch2/users/3057254/ppnerzs3.jfs
Transferring file: control_e6184b2c-ae62-4a1 | 3 kB | Â 3.6 kB/s | ETA: 00:00:00 | 100%
Transferring file: clusterjob_e6184b2c-ae62- | 1 kB | Â 1.6 kB/s | ETA: 00:00:00 | 100%
5.34 KB, 2.33 sec (2.3 KB/sec)
JobId was parsed as: 11773405
Transferring file: exitcode_e6184b2c-ae62-4a | 0 kB | Â 0.0 kB/s | ETA: 00:00:00 | 100%
Transferring file: stdout_e6184b2c-ae62-4a1a | 0 kB | Â 0.1 kB/s | ETA: 00:00:00 | 100%
ClusterJobs Command Exit Code: 1009
No files to transfer.-
July 3, 2023 at 12:56 pm
MangeshANSYS
Ansys Employeeplease refer to the link provided on June 9th. I am pasting it here for reference
Please see this documentation page for setting the environment variable
June 21, 2023 at 4:29 am
karagol
SubscriberGeneraly universy HPC system are Linux. So you have to use linux PATH in your .bashrc. For example:
export AWP_root231=/opt/apps/ansys_ins/v231
- The topic ‘RSM Configuration Error: AWP_ROOT231 is not set on cluster compute node.’ is closed to new replies.
3387
1052
1050
886
852
