Ansys Free Student Software
RSM Config
    • Moritz Baierl
      Hey folks,
      I`m trying to setup a cluster with Ansys 2022r2 and my jobs on particular nodes fail. There is one master (a computational node itself) and 4 dedicated nodes.
      This is the logfile from the RSM testjob on my workstation:
      However if I´m trying to submit a testjob to the localhost on node1, the job also fails. Here is the log file from Node1:
      Does anyone know where the issue might be an how i can troubleshoot it?
      Thanks, Moritz
    • MangeshANSYS
      Are you using ARC as scheduler?
      Did you follow the steps in this example to configure the cluster ? https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_rsm/eg_adv_arc_multi.html
  • The topic ‘RSM Config’ is closed to new replies.
