TAGGED: chemical-reaction, fluent, materials, scheme, scheme-procedure
January 25, 2024 at 7:00 pm
Mike H.
SubscriberHello,
Background: I have a large chemical reaction mechanism running in 2D Fluent. It consists of 24 reactions and 17 species. I am looking to do sensitivity studies, where I turn off a reaction, then re-run to get its contribution to the results.
I previously tried deactiviting specific reactions in the mechanism be de-selecting them. However, for reasons unknown, that did not actually deactivate them. A sure way to deactivate is to set the pre-exponential factor to a small fraction of its original value, say, two orders of magniutude lower. This effectively turns off the reaction.
Now to the issue. Doing this with the GUI is painful, so I am doing it with scheme commands.Â
Problem: The (rpsetvar 'materials mymaterials) does not actually update the materials database or the GUI.Â
Possible Solution: By searching through this document [https://www.cfdyna.com/CFDHT/SchemeLanguage.pdf], I found a command called set-all-materials!. This one actually works and updates the GUI values.
Question: Does anyone know why rpsetvar doesn't work? Also, does an easier way to update kinetic parameters exist (non-GUI)?
Thanks.
BTW, here is my workflow:
(define mat (%rpgetvar 'materials))
(define mymaterials (replace mat 1.5e+14 1.5e+12))
(set-all-materials! mymaterials)where "replace" is a scheme procedure I found online:
(define (replace lst find repl)
  (if (pair? lst)
    (cons
      (replace (car lst) find repl)
      (replace (cdr lst) find repl))
    (if (equal? find lst)
      repl
      lst))) -
February 2, 2024 at 1:49 pm
SVV
Ansys EmployeeHi,
To change the Arrhenius coefficients without GUI, one way is to transcribe reactions into a Chemkin mechanism and then use a recorded journal to read another version of the mechanism.
Please note, as per part of forum policy, we cannot debug/write scripts.
February 2, 2024 at 3:04 pm
Mike H.
Subscriberv.v.,
Thank you for the suggestion, and I appreciate that scripts can break Fluent if not careful! I am doing some other work in Chemkin, so I will look into that.Â
Can I import multiple Chemkin mechanisms and then switch between them in cell zones? Or, do I overwrite the mechanism each time I import.Â
Thank you.
- The topic ‘rpsetvar not working for materials’ is closed to new replies.
5824
