TAGGED: bearing-load, modal-analysis, motor-design, rotor-dynamics, springs
February 24, 2021 at 1:16 am
ah05085
SubscriberHello all,
I'm having trouble conducting modal rotodynamic simulation, specifically regarding inputting springs. From my reference it seems as though I need to attach the springs to a vertex. I only have a face to attach the springs and I'm assuming this is not going to give me the results I want which is to simulate bearings. It is mandatory that I create a line body like the reference picture or can I just create a center vertex to use for my longitudinal springs on the exterior xyz axes.
reference video
February 24, 2021 at 6:04 am1shan
Ansys Employee,nWhy don't you add a bearing connection instead of spring? Please check this discussion on the forum /forum/discussion/comment/107804#Comment_107804.nRegards,nIshan.nFebruary 25, 2021 at 1:58 amah05085
SubscriberI wanted to conduct the same experiment with my model. Is there a way to find the center of my cylinder's end face in ansys or do I have to do that in spaceclaim? Thanks for the great link. nViewing 2 reply threads- The topic ‘Rotordynamic modal analysis: longitudinal springs’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3862
1414
1220
1118
1015
