Rotor is mounted on journal bearings. is cylindrical support be used in analysis
    • sudhakar917
      The geared rotor is supported on the journal bearings on either side. I would like to estimate the expansion of gearwheel under various speeds.
      Is it ok to use cylindrical support as B.C (boundary condition) in the region of journal bearing?
      Thanks,
      Sudhakara
    • Ashish Khemka
      You can try defining bearings: 9.12. Bearings (ansys.com)
      Ashish Khemka
    • sudhakar917
      I have carried out the analysis with cylindrical supports – the expansion is 90 microns.
      The same analysis with journal bearing (with stiffness & damping properties ) gave 220 microns of expansion.
      I am not able to comprehend the deviation in results.
      Please clarify, which support is correct.
      Sudhakara
    • Ashish Khemka
      Did you turn on the large deflection? If not then please try turning on the large deflection under analysis settings.
      Ashish Khemka
