September 1, 2021 at 10:22 am
Abubakar
SubscriberHi sir,
Is there any parameter that can tell me whether my flow is rotational or irrotational? also, what is the significance of having the knowledge of irrotational or rotational flows?
Thank you,
Abubakar khan
September 1, 2021 at 12:20 pmaitor.amatriain
SubscriberYes, the vorticity. A flow is irrotational if and only if vorticity (the curl of velocity) is zero at all points.
If the fluid is assumed to be incompressible, irrotational flows are interesting because the momentum equation is reduced to the Laplace equation for the velocity potential. Laplace equation is linear, so it admits a superposition of elementary solutions. This the basis of what is called the potential flow theory:
Potential flow - Wikipedia
September 2, 2021 at 4:36 pmAbubakar
SubscriberThank youSeptember 3, 2021 at 6:38 amaitor.amatriain
SubscriberYou are welcome!
Viewing 3 reply threads- The topic ‘Rotational vs irrational flows’ is closed to new replies.
5799
