November 8, 2024 at 11:49 am
aknaydn
SubscriberWhen we run the Rotational_Act_TR example in the examples in the Ansys Maxwell library, movement to +29 degrees is currently observed. Shouldn't there be a movement to 29 degrees in the other direction when the direction of the current changes?
When the polarity of 5.97 V is changed in the external circuit and current is applied in the opposite direction, no change in torque, position and speed is observed. Â Only the change in the current passing through the winding is observed.Â
November 8, 2024 at 3:31 pm
erik.kostson
Ansys EmployeeHi
I would suggest to post this in the electronics forum (Maxwell).
https://innovationspace.ansys.com/forum/forums/forum/discuss-simulation/electronics-2/
All the best
Erik
