October 14, 2021 at 2:52 am
shyamsundar
SubscriberHowdy Folks, I have been trying to recreate this simulation defined in this paper. I have attached the boundary conditions and the results. I have been trying to apply define remote displacements to prevent motion except rotation but I have not been able to solve it. I have been trying to use ANSYS Static Structural. Please let me know if I am using the right boundary conditions and solver.
October 16, 2021 at 4:38 pmpeteroznewman
SubscriberStatic Structural is the right analysis system for this.
The boundary conditions figure is a section view, I assume, and you are going to use a symmetry boundary condition to do a half model, is that your plan?
In Ansys, use a Fixed Support on one end and apply a Moment to the other end. I expect the rotational velocity is small and would have a negligible effect on the stress so can be ignored.
October 28, 2021 at 2:49 amfernando.cebrera
SubscriberI've done some similar simulations using modal to find mode shape results.
I usually use remote displacements to constraint the models, would you please share the boundary conditions?, I think there is an issue with the image.
Regards!
Viewing 2 reply threads- The topic ‘Rotation and Bending of Transversely loaded shaft’ is closed to new replies.
5589
1885
1403
1298
