February 28, 2017 at 9:00 am
Nikita
Ansys EmployeeHow do I rotate views without knowing which way is the top view, for example in SpaceClaim Direct Modeler?
August 25, 2017 at 9:37 pm
pgl
Ansys EmployeeWhile in 3D mode, you can use the "Snap View" tool, located in the "Orient" group on the "Design" tab. You can click a face to view it head-on, then click, drag, and release the mouse towards the top, bottom, or sides of the design window to ‘throw´ the face to that side. To display a straight-on view of a planar face, select the face and click Plan view in the Orient group on the Design tab.
- The topic ‘Rotating views without knowing which way is the top view in SpaceClaim’ is closed to new replies.
1890
1414
1304
