May 24, 2023 at 4:05 pm
Samuele Luigetti
SubscriberHello,
is there a way to apply 2 rotating force with different direction on a single structure?
May 25, 2023 at 2:32 pm
dlooman
Ansys EmployeeYes. A rotating force doesn't have to be defined with the "Rotating Force" in Mechanical. It can just be defined with a complex "Force" as shown below. You can define as many complex forces as you want. Note that to define a force rotating about Z in a positive sense (right hand rule) you have make the imaginary component negative. You would think that a positive rotation would be positive X into positive Y, but it's not.
May 25, 2023 at 2:35 pm
Samuele Luigetti
SubscriberOk thanks so it's like a trick to fix the issue, it's not possible to use directly the properly rotating force
May 25, 2023 at 2:49 pm
dlooman
Ansys Employee-
May 25, 2023 at 2:57 pm
Samuele Luigetti
Subscriberok so you suggest to shift 180 degree to change the direction?
Another thing, i do not understand how it's calculated the rotating force...i mean on the help there is F=m*r*w^2, where w is the rotational velocity of the structure but which? since i can't define a rotational velocity in the full harmonic response
May 25, 2023 at 3:01 pm
dlooman
Ansys EmployeeYes. In a harmonic, the frequency you define is the rotational velocity. That's one advantage of the Rotating Force load. If you solve for a frequency range, the unbalanced force will be computed for each frequency automatically.
May 25, 2023 at 3:13 pm
Samuele Luigetti
Subscriberyes right i understand thank you very much for the support
- The topic ‘rotating force’ is closed to new replies.
6445
