March 14, 2023 at 8:15 am
tim.dukes
SubscriberHi Support I have a question on the new rotating fluid zone.Â
In the attached file I have set a fan speed of 600RPM.Â
I would expect the results to be quite different if I set the fan speed at 60RPM as in the velocity at 600RPM speed should be a fair bit higher?
Have I set this up correctly or is this not how this tool should be used?
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​​ -
March 14, 2023 at 10:36 am
Devendra Badgujar
Forum ModeratorHi Tim Dukes
Let me look into this and will get back to you.
March 16, 2023 at 8:00 am
tim.dukes
SubscriberAll sorted with this my setup was causing the issues.
March 17, 2023 at 1:40 am
Devendra Badgujar
Forum ModeratorTim DukesÂ
Thanks for the update. Let me know if you need any further assistance.Â
Regards.
- The topic ‘Rotating Fluid Zone Question’ is closed to new replies.
