April 11, 2024 at 4:40 pm
Fretz Sil
SubscriberHello.
I am trying to simulate a rotating channel. It has an inlet and an outlet and the bottom wall is heat flux. The channel is rotated with respect to a certain axis as shown in the figure. I have validated the result in stationary conditions but the problem arises when I try to match the rotational data (I used reference frame motion in cell zone condition). They just dont make sense. I wanted to know how to approach this certain problem in case of rotation. Do I use CFX or Fluent ?
April 12, 2024 at 1:26 pm
Forum ModeratorWhat's driving the flow? Both Fluent and CFX have options for moving mesh and reference frame, but I'm not sure what you're wanting to actually model.Â
April 12, 2024 at 1:30 pm
Fretz Sil
SubscriberIts actually a channel used for turbine blade internal cooling and I am trying to validate a paper's experimental data. For all I know, the channel has one velocity inlet and a pressure outlet and its rotating about an axis.
April 12, 2024 at 1:44 pm
Forum ModeratorYou may be OK with Fluent's reference frame then. But if the whole channel is moving will it influence the flow? If not does it need to move?
April 12, 2024 at 4:19 pm
April 15, 2024 at 8:33 am
Forum ModeratorAh, you may want to model the whole domain and include some up and downstream space.Â
- The topic ‘Rotating channel flow’ is closed to new replies.
6795
1332
1152
