July 16, 2023 at 4:36 pm
Eman Magdi
SubscriberHello all,
I am new to ANSYS and I'm trying to run a simple acoustic analysis on a room with a sound source and receiver. Most of the examples I'm finding involve the use of the Acoustic Extension which can only be used in ANSYS 19.2, this example clearly explains the steps I should carry out: https://www.google.de/books/edition/Acoustic_Analyses_Using_Matlab_and_Ansys/LXfOBQAAQBAJ?hl=en&gbpv=1&dq=Sound+Inside+a+Rigid-Walled+Cavity&pg=PA225&printsec=frontcoverÂ
Is there an alternative to doing such an analysis using ANSYS 2023? I have tried setting receiver and source nodes, but not sure how to move forward without the acoustic extension. Alternatively, is there a way to get access to ANSYS 19.2? I have looked at the prior releases but they do not go back to that version.
Thanks!
July 16, 2023 at 5:38 pm
- The topic ‘Room Acoustic Analysis using ANSYS 2023’ is closed to new replies.
3792
1388
1188
1095
1015
