February 15, 2021 at 12:31 pm
amitej.p.5
SubscriberIn the ANSYS Academic version 2020R1, a tab was created 'ROM Viewer' on the Workbench page after 'creating ROM'. But in the R2 version, I couldn't manage to find the ROM Viewer tab. nI had attended a webinar where they have specifically mentioned about the imporvements incorporated in the ROM Viewer in the R2 version, but I don't know how to access ROM Viewer in the R2 version. nPlease help. Thanks in advance.nAmitej.n -
February 22, 2021 at 1:36 pm
Keyur Kanade
Ansys EmployeenAre you using student version? nPlease check out what is included in student version at nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
February 22, 2021 at 2:10 pm
amitej.p.5
SubscriberHello Keyur.nYes I have been using the Student version all along. 2020R1 earlier and now 2020R2. 3D ROM is included under the Design Exploration tab in the toolbox on the Workbench page.n -
February 23, 2021 at 2:44 am
Keyur Kanade
Ansys EmployeePlease check Whats Included section in nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
February 26, 2021 at 4:36 am
ramgopisetti
SubscriberROM is an snapshot of your designpoints so that it allows users to use as an component in the System design, the possible way to look into ROM is either export to FMU and check the standard herenyou can use MATLAB, to open FMU files, that said, this file formt will not help you to visulise the countor of your criteria, rather return an numerical value. nThe second approach is use Response surface, It has sliders to interact witht the surface you have created( an chruned down version of FMU). If your aim is to visulise the 3D with all contours, please contact your nearest ANSYS Authorised Reseller or your IT Team, They might help you to setup the all requriements n
Cheers,nRamn
March 1, 2021 at 2:16 pm
Stephen Orlando
Ansys EmployeeArray the ROM functionality (including the ROM Viewer) is being moved to TwinBuilder as of 2020R2. Please see ROM Builder Preprocessing (RBP) for Fluent in the Add-on Packages section of the download page. I didn't see the webinar but the viewer they were likely referring to was the one in TwinBuilder.nSteven
Viewing 5 reply threads
- The topic ‘ROM Viewer’ is closed to new replies.
