October 9, 2024 at 5:16 pm
Saeed
SubscriberHello,
I have a question regarding tutorail 16 of Rocky. in that mixing simulation particles does not dissolve in fluid and they make a suspension system. Can you please help me with how to run a simulation that particle dissolve during mixing ?
ThanksÂ
October 10, 2024 at 7:49 pm
Lucas Bertollo Baggio
Ansys EmployeeHello Saeed,
Although this phenomena is not enabled by default on Rocky, you can enable it via Solver SDK.
You might start with an example: download the current modules package from the customer portal (Current Release (ansys.com)) and access the transient size scale source code from the Source Codes/Simple Modules folder.Â
This is a source code from a module that has what is needed to reduce DEM mass and volume.Â
What needs to be done is to correlate this with the source terms that are sent from DEM to Fluent. For any deeper help, please reach the Rocky support.
best regards,
Lucas
5709
