May 17, 2024 at 6:56 pm
kiran.purushothamakeshavan
SubscriberHey,
I was trying to solve tutorial 14 from ansys rocky tutorial guide, I'd like to know if you could please tell me what this means.
I am on page 677, when i choose the fluent .cas.h5 file I see this error as shown above, since it's a standalone fluent setup file, I was not able to find the ansys file log to understand the error.
This is the error I see on a file by name 'debug'
[0517/151210.783:WARNING:resource_bundle_qt.cpp(115)] locale_file_path.empty() for localeÂ
[0517/151212.370:WARNING:resource_bundle_qt.cpp(115)] locale_file_path.empty() for localeÂPlease advise.
Thanks,
Kiran -
May 20, 2024 at 2:18 pm
Lucas Bertollo Baggio
Ansys EmployeeHello Kiran,
This is a 2-way coupled tutorial that recquires a Fluent license. If you already have it, you could check the version compatibility with your Rocky license.Â
Kind regards,
Lucas
May 20, 2024 at 3:25 pm
SubscriberHello,
I am using fluent 2023R2 and also Rocky 2023R2, could this be causing an issue?How can I know if the two versions are compatible?
I do have license for both
Thanks,
Kiran -
May 21, 2024 at 7:37 pm
Subscriber -
May 21, 2024 at 7:43 pm
Ansys EmployeeHi Kiran, please check if you have a 'fluent' folder inside your Rocky installation folder (Program Files/Ansys Inc/v232/Rocky). Otherwise, try to re-install Rocky + checking the Fluent coupling checkbox on the client installer.
May 21, 2024 at 8:06 pm
SubscriberHello Lucas,
Thanks for your reply, I do have the folder 'fluent' in my Rocky folder (Program Files/Ansys Inc/v232/Rocky).
Can you please tell me about other reasosn as to why I'm seeing this error?
I even tried installing rocky again to check if everything works but the issue is still the same.Regards,
Kiran -
May 22, 2024 at 1:19 pm
Ansys Employee-
May 31, 2024 at 9:21 pm
SubscriberHey,
The coupling was successful, thanks for your advice.Â
However, the 2 way coupled solution was not successful.I was unable to see the fluid particle interaction.Â
Please advise.Thanks,
Kiran-
June 3, 2024 at 11:33 am
Ansys EmployeeHello Kiran,Â
how would you like to see the interactions? you can see the fluid side by coloring "CFD Coupling" entity in a 3D view by any property in Nodes, for example. To do this, create a new 3D view, make the walls transparent and click the CFD Coupling on the Data panel, go to the Coloring tab, make visible and check Nodes with the desired property. Â
- The topic ‘Rocky tutorial 14: fluent error’ is closed to new replies.
5824
