June 16, 2025 at 12:57 am
Saeed
SubscriberHi,
I am seeing an issue with my simulations recently which slowed down the progress of them significantly. As you can see in the attached figure, the exporting Fluent Mesh data to Rocky takes a very long time to be done and now for the simulations I used to get ETA of 15 days, I am getting 86 days. can you please help me with solving this porblem or let me know if there is a way to find out what is causing this slow down ? Â
Thanks
June 16, 2025 at 3:33 pm
Lucas Bertollo Baggio
Ansys EmployeeHello,Â
I can't see the image. Did you change your simulation target CPU(s) or GPU(s)? Did you change anything in the setup to get this delay?Â
June 16, 2025 at 4:45 pm
Saeed
SubscriberDear Lucas,Â
Thank you for your reply. I attached the image again. I did not change anything from in the setup. I have run several similar simulations and they were are in the range of 2 weeks or so. started some simulations 2 weeks ago. the first week i was getting the same ETA around 15 days, and suddenly during the second week the ETA went to 80 days. I noticed that the exporting fluent mesh data to Rocky is taking a lot of time, while it used to pretty smoth and quick before. Can you please help me with this ?
Thanks
June 17, 2025 at 1:41 pm
Ansys EmployeeAre you using the exact same version from both softwares?!Â
Why are you doing the simulation again if you have already run the same setup? I mean, what are the changes for this one?ÂIf you have access, I would consider opening a ticket for the support team to help you on this one.
Best, Lucas
3266
1031
1004
859
798
