Rocky coupling warning
    • Saeed
      I recently changed my ansys version to 2024R2 and wanted to do a fluent-rocky simulation which I got the folowing warning. is this something that I should be worried about ? if yes, can you please help me resolve it ? Thanks
    • Jackson Gomes
      Hi Saeed.
      The warning indicates a potential compatibility issue between the compiled User-Defined Functions (UDFs) and the current build of Fluent. Update Rocky and Fluent to the same version.
      If you are using UDFs compiled with an older version of Fluent, recompile them using the correct Fluent build to avoid issues.
      Best regards.
    • Saeed
      Thank you for your reply.
      Both fluent and rocky are same version and I am not using any UDFs.
      Thanks
