September 24, 2024 at 1:44 pm
Metropolia motorsport
SubscriberHello,
I'm building an IPM sync motor model in RMxprt and can't seem to get very far without problems. After setting up the stator and core parameters and moving on to the stator winding parameters I encouter the same error everytime I try to change either the winding type or the wire size. As I click to change either one it immediately displays the error message seen in the picture attached here.
In the error logs the first row is as follows:
With a quick google search this is some windows related issue regarding the software trying to access some protected files or something. I've tried to run the software as administrator and the simulation files as well as the software files should all be on the local disk and not on any web disk.
Any help would be much appreciated.
September 24, 2024 at 1:55 pm
SubscriberIt seems the error log can't be copy pasted for some reason, so basically it says that the exception code is 0xc0000005 and the description is "exception access violation". Module name ansysedt.exe
